pre-paid plan with unlocked iPhone 6+
I am currently with Rogers with an iPhone 4. I want to switch to Koodo with an unlocked iPhone 6+ I want to keep the same telephone number that I currently have with Rogers. What are the steps I need to follow?
Do no cancel your Rogers account. Get a Koodo prepaid sim and activate it. Once activated, go into your prepaid self serve and port your Rogers number over. http://help.koodomobile.com/prepaid/activating-your-koodo-prepaid-phone/what-do-i-need-to-activate-my-koodo-prepaid-phone The porting will effectively cancel your Rogers account. Rogers will bill you out on their end for any cancellation fees, etc.
Go into any Koodo location, buy a koodo nano Sim card and do a Sim only activation while in store. The Sim card is only $10 and the koodo employee can do the port over for you. You'll need your rogers account info to do the port over in store. Once the port over is complete, your rogers account will cancel and rogers will bill you for any charges you may have with them. You can choose any koodo plan and since you are on a month to month basis with koodo you'll also get 10% off your plan. Hope this also helps! 🙂
Should have added that my suggestion wasn't for prepaid plans.
