Pre owned phones
  • 15 December 2018
  • 7 replies
  • 322 views
Just a quick question. Does the pre owned phone has the original box and all accessories ?
Best answer by Mats 15 December 2018, 03:38
This is what certified pre owned phones come with.
https://koodo-support.acromediainc.com/help/certified-pre-owned-phones
No, more than probably not... I had one and it came in a generic box without any other accessories... but not sure if that is standard or not!
So only phone and charger. What does like new means when no box with it
Like new as in the condition of the device.
It's basically a refurbished device. Similar to what Apple gives you when you need to replace your phone.
It comes like brand new not a scratch on it and you couldn't tell new from refurbished if they gave you one in each hand and you had to guess which is which. There usually isn't the plastic on the phone like a brand new one so I mean once you were to remove the plastic. I'm actually typing on a refurbished iPhone 8 Plus and it's my second refurbished iPhones over the last few years and never had an issue with either so it's totally worth the savings IMO.
Thanks a lot Paul, really appreciate it. I am thankful.
No Problem, have a good one
