Feedback
please help! connecting offline doesnt work. | Koodo Community
  • 12 September 2021
  • 33 views
Ive been getting texts that I've been paying for my prepaid plan for months but connecting  to my data is not working, i tried removing my sim card, restarting , updating and everything. The only thing that i think could be an issue is that we got a new internet provider.. please please help me :( i need this fixed
my phone is Iphone XR
Best answer by Dennis 12 September 2021, 04:49
When you login to your prepaid self serve, what base plan does it say you have?
Do you have any data boosters?
Yes i have gotten boosters, i have majority of them, if not less. But I definitely have them. And sadly I haven’t been able to log in to see whats wrong because i forgot my login and when i try to change my password it says my emails are incorrect, when i use my phone number for the forgot emails it says my phone number doesn’t exist.
Make sure you are logging Into the correct self serve.
Try this link
https://prepaidselfserve.koodomobile.com/?intcmp=MyAccount_Login_Prepaid_LoginRegButton_062019
Connecting offline ? Do you mean problems with wifi / new home internet provider?
If the problem is with mobile data, take a spin thru this page:
https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone?search_api_views_article_search_fulltext=iphone%20apn
