Please help!
 I can't access my data, but I can call and text. What is happening? Thanks.
Make sure your data is turned on. If it is, you can perform a reset of your network settings under SETTINGS > GENERAL > RESET > RESET NETWORK SETTINGS. You'll lose your WiFi passwords, but the rest of your data will be fine.
It worked thank you!
