plan differences
  • 27 June 2019
  • 97 views
out of curiosity i was looking at different plans that were available to me. i currently have the $100 plan which is 10GB of data and unlimited everything else. ($100 10GB UL min Plan TL SFD) and i came across a plan that was $75 but has 12GB of data and what appears to be everything else as well ($75 12GB UL min Plan SFD). in brackets you can see what koodo named the plan and the "TL" is missing from the second one, and i cant seem to figure out what that means. it didnt say if it was a promo plan or not either, so i just want to make sure it is not too good to be true. Thanks
Are you on Tab Large plan?
And I don't see $75 , 12GB... I see $75 with 9GB or $85 with 12GB plan.
I think right now Koodo had an offer of $75 for 15GB also. It should be available in your selfserve as a "special deal" when you upgrade your phone. If you don't see it, you could try to contact Koodo directly and ask a rep to help.
A screen shot of what you are seeing might help
i believe large or extra large because its the xs max and i purchased it the day it came out
It looks good. Don't worry about it
