phone calls wont work
I am unable to make and relieve calls and i am connected to koodo network. when I call my cell phone from land line it just hangs up after dialing and when i call from my cell to land line nothing happens.
Did you recently port your number over?
Yes on Sunday
Amanda Nowlan wrote:
Yes on Sunday
Looks like a port issue.  The port should be completed but it looks like a hiccup.  you will need to contact Koodo and have them look into the port to see where the snag is
Yes on Sunday
Thank you for you help !
Yes on Sunday
you also can try a hard reset. take battery and sim out of your phone and put them back after 5 minutes.
