Phone calls in ontario its long distance calls charges are applied ??
My plan says 55 unlimited Canada-Wide Calliing.I get the same message all the time ( long distance calls charges are applied ) when I try call mississauga while I in Hamailton ontario why??
Im travelling in ontario area every  week its long destant charges on my calls ?
Hi John, that is a standard message for all long distance calls, because "the system" doesn't know that you have unlimited LD calling. If you dial a 1 in front of the number, you won't get that message any longer 🙂
Hi Sophia,
I can used my phone any where in koodo network ? and the data to ?
Im new with Koodo mobile I came from Windmobile.
john wrote:
Hi Sophia,
Im new with ...
Correct.
