not receiving phone calls and texts
  • 28 March 2021
  • 4 replies
  • 201 views
I am not receiving any incoming calls or texts, scheduled a call back it's been 4 hours and I have not received it yet.
I restarted the phone, made sure do not disturb is off as well as airplane mode off.
Best answer by Goran 29 March 2021, 00:33
Is it showing any service/emergency calls only, etc?
Did it work before?
Are you a new customer?
Are you able to complete outgoing texts or calls? Does data work?
Did you port your number recently?
Have you tried to reset your network settings?
Yes I ported my number recently. It was a home no. until I asked Koodo to turn it into a cell no. with the new phone I purchased from them a week ago.
You won't be receiving calls until the porting process is complete.
Home numbers take a little longer too in order to comète.
