Not receiving calls, messages
  • 4 August 2021
  • 75 views
I just switched my plan from Freedom to Koodo
and I am using it as a esim
I can sent calls only
no receive or sent messsages, calls
anyone can help?
I think maybe the port didn't go through properly yet. When you visit self serve, does the correct number show there? Have you restarted your phone after you ported your number?
I have been trying to do everything
but still not working
I can only send calls
Right, but you didn't answer my question, what number is shown in self serve? Is it your phone number or some randomly assigned temporary number?
Also, is your old Freedom line still active?
And when did you port? like today? What time?
anyone can help?
Did you restart your phone after porting your number over to Koodo? Have you changed your APN settings on your phone? https://koodomobile.com/en/help/setting-data-your-non-koodo-phone
