Not able to send n receive international text messages...
(empty)
I got an iPhone 6 .... Pls help
What happens when you try to send one?
It says message sent...but not delivered on the other end..I don't receive their messages too
I was using an iPhone 4 n moved to iphone6 and also changed the service provider from FIdo to koodo
Make sure that on iMessage in Send & Recieve it is your phone number and not your email that is set, otherwise just turn off the iMessage and send a sms see if it works.
Tried that ...not working
Try going to your settings to set "Send as SMS" option and see if that will work. Maybe apple is having a problem with their cloud!!
Do you have carrier/signal in Brazil?
Tried that too
Do you have any signal though?
Userlevel 3
Hello Arati,
Have you succeeded sending/receiving international texts? Also, is the carrier that you are trying to text and receive texts from on this list http://koo.do/TAUO5h?
Keep us posted!
