no signal
I just activated a prepaid on iphone 3Gs, but got no signal why?
Is the phone unlocked? Also make sure that 3G is enabled under settings->general->network->enable 3G.
Curtules wrote:
Is the phone unlocked? Also make sure that 3G is enabled under settings->general->network->enable...
If you're not getting signal everywhere, if so, it may be phone problem, if only in one location turn iPHONE off/on,pull SIM, enable 3G like Curtules suggested if not working call 1-866-995-6636 to check coverage and troubleshoot
it can take up to 24hrs for your phone to become active but usually comes to life in anywhere from 15 minutes to 2hrs. just turn the phone off and take out the SIM Card and wait a minute or so and then replace it and try again like Mat suggested. Also make sure airplane mode isn't on and that it isn't on GSM or 2g only like curtules said.
If it is an unlocked iPhone 3GS, you maye need to setup your iPhone via iTunes. Check out the instructions here: http://koodomobile.com/en/on/switch2koodo-step-3-d.shtml
Lorsque je fait désactivé le 3G y'a plus de signal ? C'est normal ?
Actuellement c'est normal chez Koodo d'avoir aucun signal si vous avez désactivé le 3G. Koodo utilize une réseau 3G et non 2G pour la service cellulaire.
Ah, ça consomme beaucoup l'autonomie de la batterie 🙂 Merci beaucoup
