No more LTE network
  • 21 February 2016
  • 2 replies
  • 35 views
I changed plan yesterday to the 40$ Unlimited minutes, 1 GB data, Unlimited texts, but seems like I don't have LTE network anymore. Is that normal ? Does it take time to adjust ?
 changing your plan wouldn't have an impact on the data connection speed so there must be something else going on.
try restarting your device,
check your network settings make sure lte is on
general...cellular...enable lte
Thanks it worked !
