new phone help
  • 2 June 2015
  • 1 reply
  • 372 views
i had a samsung s3 and it had a koodo sim in it and i just got an iphone and bought a nano sim. how can i activate it while keeping my current plan??
Best answer by Mayumi 2 June 2015, 00:48
Self serve > Mobile Phone > Swap Mobile Phone > "Does the new phone you're upgrading to use a SIM card?" > Select "yes", and enter a new sim # then continue But self serve system is down now. So I guess you have to wait for awhile and try it later... 😞
1 reply
