Network issue after roaming?
  • 25 February 2013
  • 4 replies
  • 12 views
I was just in Chicago for 5 days and now that I'm back my iPhone wont connect to the koodo network at all. Any idea how I can get this fixed? Only wifi works and my network says no service. I can't even dial 611 to talk to anyone at koodo.
Have you tried taking out the SIM Card and reseting the device?
You could also check if the APN settings are correct: http://support.apple.com/kb/ht2283 Settings for Koodo: http://koodomobile.com/en/ab/non-koodo-phone-data-setup.shtml Especially the bit where it says APN: sp.koodo.com is important 🙂
You could also check if the APN settings are correct: http://support.apple.com/kb/ht2283 Setti...The APN is just for Internet and mms, he said nothing works. You can try manually searching for service towers.
Hi there, if it still doesn't work, you contact our technical assistance. We can be reached at 1-866-995-6636 from a landline, option #6 🙂
