Need help regarding iphone 5c
last night i change on here my sons plan from $28 one to a $40 one so he'd have data. still not allowing him any data however, even though it successfully changed on here.please advise how we can get the data working?
Is your phone from Koodo? Make sure your APN settings is set to Koodo.
Is your data on?
Also,check his plan's add-on if he has data block on his account. If it is, then remove it.
If you don't see it and those suggestion didn't work, call Koodo *611 option 6 for tech support.
Hi Kelly !
Did you try Mayumi's suggestion ? Please note that if you still have the old data block add-on, it will not appear on Self-Serve even though it's still there. If that's the case, your best bet would be to contact us.
Keep us posted 🙂
