need help
i need help
What do you need help with? The more details the better.
My phone Saids no service
was it working before?
Did you try restart your phone? (Power off fr awhile and turn it on)
If a restart didn't work, pull the Sim card and restart the phone. Or try toggling airplane mode. Hope it helps
Have you disabled 3G by mistake?
If none of the above work, go to SETTINGS > GENERAL > RESET > RESET NETWORK SETTINGS.
Your phone will restart and you'll lose any saved WiFi passwords.
