Need a solution for low battery life on iPhone 4
i have an iphone 4 and its battery is getting pretty tired! i was thinking of buying a mophie battery case but when i saw the price i decided to forget it.... does someone know a cheap but good quality battery case i could get? or where i could get one? or if you have another suggestion? thanks!
here's a list of battery cases http://www.pcmag.com/article2/0,2817,2371912,00.asp the charge it 2x is quite a bit cheaper than the mophie. My friend uses an exteral power pack and charges his phone through it so that's another option you could consider. Or you could consider battery replacement http://www.apple.com/ca/batteries/replacements.html
https://play.google.com/store/devices/details?id=nexus_5_black_16gb That'll fix it.
LOL ^ that's another option 😛
Time for a new phone. Or maybe a portable battery charger for cheap. It can be annoying to carry around though
Battery doctor or other apps like that.
