My KoodoIiPhone 4s does not ring on any calls
Best answer by Angelea Leaming 8 July 2014, 17:06
Is the "Do Not Disturb" off? Its a little moon icon in the pull up menu. Try a soft reset. Hold down the home button and lock button together until the screen goes black and the apple comes up, this will simply refresh you to the network. Which might solve all your problems.
1 reply
Userlevel 2
