my iPhone 5s won't turn on
  • 21 June 2015
  • 4 replies
  • 14 views
Phone worked fine this afternoon & had about 80% battery left. Tried to use it a little while ago & it won't turn on. Put it on charger but it stayed black so popped out SIM card. Nothing happened. Any ideas?
Hey Charlene, Hold the power and the home button together. The apple should come up after a few seconds of holding the buttons. Once it does, let go of all the buttons. Holding them past that point can result in a total loss of data so be careful.
Hey Charlene, Hold the power and the home button together. The apple should come up after a fe...Even if you get into recovery mode, you can get out of it without reflashing the phone.
Userlevel 3
Hey Charlene,
Has Mathieu's advice helped? Are you still encountering this issue?
Let us know!
Userlevel 4
Connected it to a computer and try to restore in iTunes.
