My iphone 5s has no service right now. Tried all possible ways to fix, but none worked. Help!
no service
Give it a couple more restarts and network on and offs.s. Can you set network selection to manual to see if Koodo pop up?
Oh and reset network settings too in case you haven’t also tried that. I know you sai everything but anyone can forget a thin or two in a lon list of stuff to try.
Goran wrote:
Oh and reset network settings too in case you haven’t also tried that. I know you sai everything ...
Thank you Goran for the reply. Actually I am outside of Canada, and without international voice/data roaming enabled for account, there will be no service at local. After both added, together with your advice, my phone finds service. I appreciate your reply.
Have you disabled 3G?
Hey Ning,
Goran's right! Resetting network settings should help. This link: http://koo.do/1Bf3grB will guide you through the steps.
Let us know if you still need help!
Tayeb A wrote:
Hey Ning,
Goran's right! Resetting network settings should help. This link: [url=http://koo...
Actually I am outside of Canada, and without international voice/data roaming enabled for account, there will be no service at local. After both added, together with your advice, my phone finds service. Thanks a lot for your help.
