multiple Incoming calls from the USA
  • 20 September 2013
  • 1 reply
  • 10 views
tonight my phone lost signal and then the only signal it would get was AT&T. I was in Canada still but started getting incoming calls from different places in the USA. Any idea what is going on?
Best answer by Yannick 20 September 2013, 14:12
Hi Wolf, I assume that you're located close to the border. You should select the network manually, to avoid accidental roaming (signal from US towers could be stronger). Go to Settings - Carrier and put it on "Off". Keep us updated! ________________________ If you see a good answer, give it a star.
1 reply
