Messaging without wifi
  • 16 November 2014
  • 82 views
I have the iPhone 6. Why can't I receive text message when I'm not on wifi. I turned on the setting in messages for sending a text when iMessage is not available.
Userlevel 3
If you are texting another iPhone it sometimes wont send as a text if the other person has their iMessage off. Try clicking on the actual text a couple of times and sending as text then it should always text. Good Luck
Your data is not turned off by any chance, is it?
Your data is not turned off by any chance, is it?you need data to send a texte?
Your data is not turned off by any chance, is it?You need data to send an iMessage using iPhone, or to send a picture message on any phone.
http://www.imore.com/why-cant-i-send-regular-text-messages-my-iphone-6-or-6-plus
