Lost/Stolen Phone, help!
lost my iPhone, most likely stolen from my workplace (awesome, right?) any clues on how to retrieve it other than using Find my iPhone because i recently updated to ios7 and hadnt yet set up my iCloud email adress, any answers are welcome!
I'd suggest either prayer or a trained bloodhound, since without tracking software enabled the odds of recovering a stolen iphone are virtually nil.
Timo Tuokkola wrote:
I'd suggest either prayer or a trained bloodhound, since without tracking software enabled the od...
bloodhound it is.
At the same time make sure you report the phone lost / stolen because until you do, you're responsible for all the charges the theif racks up. You can do so in selfserve
