long distance minuits for month on plan for phone # 780 XXX XXXX
ken wasmuth ,wainwright alberta
Hi Ken,
This is a public forum.
Are you trying to add long distance calling to your plan?  Where are you trying to call
You can learn this from your account information in the self service section on Koodo's website. If this is a new account, with a limited number of minutes, there may be a charge if you use more than the pro-rated number of minutes based on the number of days between the account being created, and the beginning of the first billing period.
Hello Ken,
Long distance minutes are covered if you're under a canada-wide plan!
