Long Distance
I have a $65 plan a month that includes six gigs and I would like to be able to call family in the states from Canada unlimited and unlimited texting as well is there a plan for this or is there an add on for this
Best answer by Mats 16 February 2019, 19:09
There are no plans that include unlimited minutes to the US. The add-on Allan mentions would be the cheapest and most minutes way to go. There is also a $3/month long distance saver that brings the $0.60 rate down to $0.20. The link below has your options.
https://www.koodomobile.com/help/long-distance-calling
$10/month will you get 1000 US minutes. Otherwise it is $0.60/min
Texting to anywhere in the world is free from Canada.
Otherwise you can get your family to use whatsapp or something similar that let's you place voice calls via the app at no additional cost.
There are unlimited voip calling options. Skype charges 4 dollars a month for unlimited calls to American numbers.
