login not verified
  • 30 April 2018
  • 1280 views
I cannot login in to top up my account.  I received an email that says I'm registered but I then when I try to log in, I get a message that says unable to verify my email.
We're you able to login before?
We're you able to login before? Are you logging in to the prepaid website? If you try the postpaid one, you will get an error.
Heres the link you should use to login: https://prepaidselfserve.koodomobile.com
If all else fails you can top up by calling 611.
Hi  and  peace to you ! unable to log in to self serve where it used to be no problem
Searching on internet plus phone app is not working
Can you start your own post?
https://community.koodomobile.com/topic/new
We need more info and details  of  your issue.
