koodo mobile app does not work with prepaid accounts
it would be helpful if "koodo app does not work with prepaid accounts" was highlighted in the app description.
From what I know Koodo Mobile app. was only released for Postpaid!
There is a description in the Android Play Store: https://play.google.com/store/apps/details?id=com.koodo.selfserve&feature=nav_result#?t=W251bGwsMSwxLDMsImNvbS5rb29kby5zZWxmc2VydmUiXQ.. [i]Description [b]The app does not support prepaid accounts. Introducing Koodo Self Serve, an easy-to-use app that lets you manage your account from your phone: So yes it's right underneath the title in the app description, but I sure wished it worked on Prepaid 🙂
