Keep my current plan while upgrading phones
Hello, I am looking to upgrade my phone but I want to keep my current plan. Can I do so? Because I do not see my plan as an option wheh looking at options offered
Thank you
Userlevel 2
I think it would depend on the Tab you choose.  Small, Medium or Large.  I have upgraded before and was not required to change my plan
ATM it's based on a dollar value and whether or not you opt for a tab large. Large is the only one that requires not only you meet a minimum dollar threshold, but that you also pick a tab large plan. If your plan is at least 40 dollars, or 35 in Quebec, then you can get a tab medium (360) without changing your plan. Tab small (240) is only 25 dollars a month.
If you are on the old tab system still, that limits what you can see.
