Is there a better travelplan for Europe providing more text and call time that 50texts and 50minutes for $40?
Koodo Europe travel plam
Best answer by Goran 11 July 2016, 01:27
with Koodo that's it. If you want actual usage, get a prepaid Sim card wherever you are going: http://prepaid-data-sim-card.wikia.com/wiki/Prepaid_SIM_with_data There is a comprehensive list of basically every prepaid option. A fe of us here are familiar with prepaid options in several European nations so you can also tell us where you'll be going and we can help with that as well. Make sur your phone is unlocked first. I see that you put down iPhone so your best unlocking bet is via Koodo. You can use Fongo/Textnow for a free Canadian number. Fongo is free calls and 2 a month for outgoing texts while Textnow is free for both. Haven't used th latter enough yet to see the catch and I'm personally just used to Fongo. Since you'll have a very large amount of data likely wherever you go it'll let people back in Canada keep in touch with you if you so desire.
1 reply
