Is my Koodo locked phone ready for a plan?
I bought a used iphone that is locked to the koodo network. do i need to do anything special to this phone to use it on the koodo network, or can i just take it to a store and get service for it?
You can use it as is, Bobby 🙂 Just sign up for a plan, or prepaid if you wish, and insert the SIM card in your phone!
Sophia wrote:
You can use it as is, Bobby 🙂 Just sign up for a plan, or prepaid if you wish, and insert the SI...
That is as long as the phone hasn't been reported stolen and is blacklisted, then it's pretty much useless.
