Is HD Audio now supported?
I just used my Koodo iPhone 6s to call my wife's Koodo iPhone 5s and the call quality definitely sounded like HD audio, which was a big surprise.  Is VoLTE now officially supported, and does it work down to the iPhone 5 models as well?
Thanks Koodo!
Where are you located? Telus has VoLTE in AB/BC, so Koodo may have it there as well. No VoLTE in the rest of the country yet.
Ivan wrote:
Where are you located? Telus has VoLTE in AB/BC, so Koodo may have it there as well. No VoLTE in ...
I'm in Peterborough, Ontario... not exactly a large metropolis.  Her voice was definitely coming through in HD - way better fidelity than normal... I would compare it to FaceTime audio from a Macbook Pro.
HD Voice doesn't require VoLTE:
https://www.reddit.com/r/tmobile/comments/3f42uq/hd_voice_vs_volte/
Ah, that's what I was wondering.  So the question is, what changed.  If it's simply wide-band audio (better codec) I'm wondering if Koodo recently implemented support for it or if a recent iOS update maybe triggered something.  Whatever it is, I like it.
It's anyone's guess without official word as to where the change occurred but I'm glad to hear you're happy with it.
