iphone 5 with telus doesn't work with Koodo
i bought a sim card thru koodo & put it in my telus iphone thinking it would work because a few people told me it would and all it says is no service ? what do i do ? Im pre-paid ? is that the problem
Userlevel 4
What kind of iPhone is it? Did you pay $10 or $20 for the sim card?
iphone 5 & 20 dollers
You need to update the carrier settings via itunes http://help.koodomobile.com/plans-add-ons-data-and-other-services/iphone/how-do-i-activate-my-iphone
Dennis wrote:
You need to update the carrier settings via itunes http://help.koodomobile.com/plans-add-ons-d...
when i plug my phone into itunes nothing comes up ?
Make sure it's the most updated iTunes. Also make sure your active Koodo sim is in the phone.
I just downloaded itunes from the website when u told me to do that and my sim card is in there ....
You shouldn't need to update carrier settings via iTunes at all. Sometimes this helps with issues, but it isn't a required step. Is your iPhone already activated, or are you trying to activate it after a restore?
I bought the phone from a guy yesterday & i reset everything on the phone to make it a new phone went to koodo today and got a nano sim card activated it online and out it in the phone and turned the ip[hone on and all it says was no serivce
It's possible that it's not a Telus iPhone, then.
Go to Settings>General>About What does it say for Carrier? Does it say Telus?
it says koodo 15.5
Hmm… it might be the sim card. Have you tried Resetting the Network Settings or a factory reset?
yes i have , did both . Should i go to a koodo stand tmrw and talk with them, Can they check to see if its my sim card ?
Yes. Either it's the sim card or the phone. They can try another sim card to narrow down your problem
okay thanks
See my response below too
I really think the seller sold her an iPhone that's really with another carrier. There is no reason why it shouldn't work unless a) seller lied or b) phone is legitimately defective, which i doubt
I thought so too, but she says that it says Koodo in the General > About section.
Yeah even when i whipped the whole phone then set it up again it still says koodo 15.5
Oh, one last thing. Make sure that Airplane mode is turned off and that 3G is turned on under cellular settings...
Jonathan I wrote:
Oh, one last thing. Make sure that Airplane mode is turned off and that 3G is turned on under cel...
yeah it is off and 3g was on i made sure of that .
Try turning the phone off and taking out the SIM Card and putting it back in, then turn the phone on and try it again. I've had some issues with phones with SIM Trays like the iPhone or Nexus 5 and the SIM Card not sitting right when you put it in, pulling it out and putting it back in has fixed the issue for me in the past. Also it can take a little time up to an hour or so for your phone to work after you first activate your SIM card on self serve usually it's it's within 15 minutes though.
Try turning the phone off and taking out the SIM Card and putting it back in, then turn the phone...
Plus my iPhone always requires a restart when I change SIM cards.
Userlevel 2
Keep in mind, this is not 100% guaranteed. If you tried everything and you still cannot get it to connect, then your next option is to get it unlocked.
Myke wrote:
Keep in mind, this is not 100% guaranteed. If you tried everything and you still cannot get it to...
If the SIM is not faulty and it's indeed a Telus phone, I'd wager that it's defective. I don't see how unlocking it will help.
