Iphone 5 Data Usage Problem
I am using [b]iphone 5 and an hour ago, i got my data usage suddenly to 90%? At 1 PM i got the message that you have 50% usage and in 30 mins i got the message that 90% is your usage? All the background, siri, and icloud services are OFF. And even in the histroy usage of KOODO i dnt find anything. Please help me out
Best answer by Mitchell Palmater 8 October 2015, 20:02
I would suggest going to your data settings and scrolling down.
This will tell you what apps are using the most data.
Be aware that this is not abnormal, depending on the data on your plan.
Video streaming takes up a lot of data. Browsing through youtube can sometimes eat up an entire gb in a day!
Keep an eye on it!
1 reply
Keep an eye on it!
