iphone 4 wont connect to wifi
iPhone 4 won't connect to wifi anywhere now....just happened. I restarted the network settings, turned it off & on, turned it on airplaine mode.... The software is up to date.
Hi vivienne,
What error messages are you receiving when you attempt to connect to a wireless network?
Mathieu wrote:
Hi vivienne,
What error messages are you receiving when you attempt to connect to a wireless net...
Not getting an error message; it just isn't connecting/finding any networks.
Mathieu wrote:
Hi vivienne,
Could you please post a screenshot of the Wi-Fi page whenever you are at home and know that there is for sure a wireless network availalble?
Mathieu wrote:
Hi vivienne,
Mathieu wrote:
Hi vivienne,
What happened when the issue started ocuring? (Did you update the system, install a new app, jailbreak it, etc?)
Mathieu wrote:
Hi vivienne,
Nothing. It just disconnected one night and never connected again.
Mathieu wrote:
Hi vivienne,
Turn on airplane mode, and shut the phone down. Remove the SIM card as well, let it sit for about 5 minutes. After that, put the sim card back in, turn on the phone and then turn airplane mode off and see if you can see networks again.
If not, then I would suggest performing a factory reset on the phone.
Mathieu wrote:
Hi vivienne,
Thank you.  Did all that and it still isn't working. My other apple devices and others' phones are able to connect to the various Wi-FI networks.
Mathieu wrote:
Hi vivienne,
What happens if you choose 'Other' and type in the credentials for your router (i.e. both the SSID and the password)?
Mathieu wrote:
Hi vivienne,
Mathieu wrote:
Hi vivienne,
You did a full system restore? Meaning you have deleted everything and reinstalled iOS on it?
