iPhone 4 3G Data Problems
I was previously a rogers subscriber, but because of the better deals on Koodo, I unlocked my iPhone 4 and switched to Koodo. I never had any problems with data while on Rogers, but ever since switching to Koodo my 3G data is terrible (if it works at all). Texting and voice calls seem to work fine, but poor/no data connection. I have spoken with Koodo tech support and their solution was to reset network settings. I performed the reset and the data works better for a couple of hours, but then right back to no connection. I don't want to have to reset my network settings every time I need to use data on my phone. I am almost at the point where I am going to switch back to Rogers and suck it up with the higher prices. Please help!
Try another sim card. it may be a sim card issue. Or try your sim card in another phone to see if he same issues persist. Also a factory reset may be in your future
Dennis wrote:
Try another sim card. it may be a sim card issue. Or try your sim card in another phone to se...
I will try a factory reset and see what happens. Thanks.
