Feedback
iPhone 11 stuck on Silent Mode | Koodo Community
  • 4 September 2021
  • 2 replies
  • 21 views
My iPhone 11 is stuck on Silent Mode. I can flip the little bar to deactivate silent mode but it does not stay….keeps switching back to silent
The silent toggle is a physical button. If it didn't work, you might have to backup your phone, reset the phone to its factory settings and restore. If it was a software issue, that should fix.
Anyway, have you tried to push on the volumn increase button and see if it can do anything?
Is it possible you might have something stuck in between the switch? When there is too much dust accumulating on your phone, it can affect your device in different ways. I would suggest you to find something to go through the slider. If that does not work, it may be a hardware problem that will warrant a visit to your local repair shop.
