international roaming no data
hey, I just added the international roaming plan (30Bundle) for my trip to Iceland and England. I landed this morning and got the welcome to Iceland message. Everything is working but the data. I have my settings activated for internet, 3G and roaming and I can't figure out the issue! I have an iphone4. Can someone help?
Hey Matthew, I fixed your settings, check and see if all is well now. Enjoy the country of Blue Lagoon! 🙂
Can you check on your self-serve (app is easier) that you have International Data Roaming added?
Bernard wrote:
Hey Matthew, I fixed your settings, check and see if all is well now. Enjoy the country of Blue L...
It's still not working. I just turned off the wifi and checked and it's not working. I have cellular data turned on. I checked my self serve and it says the international roaming package has been added. Am I missing something? This is getting frustrating.
Have you restarted your phone? Can't hurt to try. Does it show that you are connected to a data network?
Restarted it and it works fine now thanks!
I'm glad it worked! For future reference, when account changes are made and if there's an issue, a restart will usually clear it up.
