Int'l Long Distance Saver Add on for INCOMING calls
I have the Int'l Long Distance Saver Add on and unlimited Canada-Wide Plan. Will I be changed if someone makes [b]a call to me from Europe?
Thanks!
Best answer by Timo Tuokkola 12 September 2015, 15:17
No. You are not charged ld for incoming calls received while you are in Canada, whether you have the ld saver add on or not.
1 reply
