Incoming U.S calls
So I have the Canada Wide Double Promo 56 Plan that I got awhile ago. It states I have Unlimited Canadian LD. If I receive a call from the U.S and answer it, will I get charged for LD? I know that I can call and receive anywhere in Canada and that I can't call in the U.S, but what about receiving?
Thanks in advanced.
If you are in Canada, calls from all over the world are all treated the same, no extra cost, Dave. If you travel to the US, you will pay roaming or you can then add a travel add-on.
Sophia wrote:
If you are in Canada, calls from all over the world are all treated the same, no extra cost, Dave...
Ah thank you for the quick reply. Glad to know that I won't get charged for incoming calls!
