Im currently with Koodo but wanna keep my plan and phone number but switch to a I phone 6s
I would like to switch to a I phone 6s but want to keep my plan and number
It is totally doable. You can either buy a new phone from the website or go in store. Depending on what phone you have right now a simple switch of the SIM card could do the trick.
OK yeah right now i have the Android Lg G4 but I've always like the I phones more
If you have a store near you they will set up everything for you! It's not that hard really. If you purchase it online, then a small switch on self serve will b necessary because the SIM card isn't the same size
Just FYI, Depending on your current plan, you may be able to only get the iphone on Tab S.  But you can still keep your plan
@Aaron what's your current Koodo plan, how much of a tab do you have left with Koodo on your LG G4 and were you planning on putting the iPhone 6s on a tab?
