If i use more than 1000 International LD minutes in the $50 - 2GB plan will I be charges, if so at what rate?
What will happen if i use the full 1000 Internatiolnal LD minutes in the offer? Will i be charge for my usage above 1000 International LD minutes? If I am charges then what will be the call rate?
You mean nationwide minutes? Then you will be charged the overage rate, which is 50cents/minute. Or do you have an unlimited international addon? In that case there is no limit to the number of minutes 🙂
Hi Shabbir - the current promotional rate plans offer 1,000 international long distance minutes to select countries (see below). Once your included 1,000 minutes are up, regular long distance rates apply, which can be found here.
Countries included in the plans: India, Germany, China, Hong Kong, Bangladesh, Italy, Mexico, Australia & Taiwan
Userlevel 2
Ranjan wrote:
Hi Shabbir - the current promotional rate plans offer 1,000 international long distance minutes t...
South Korea Included?
Hey Shabbir! You'll be charged the usual pay per use rates if you go over the 1000 minutes in the same billing cycle. The rates can vary depending on where you call.  You can find them here ->http://koo.do/JALDeg . Hope this answers your questions 🙂
Is the offer like this: 1000 LD min per month or one time?
What will be considered as a upgrade, I have Already switch to $55 plan from $57 plan, so that woudnt be an upgrade. if I buy a new phone lets say for a minimum for $96 from koodo online, will that enable me to be eligible for the plan?
What will be considered as a upgrade, ...
Hey daljeet 🙂
It seems that you posted your question here: http://koo.do/2cv6ztu Feel free to create a new thread whenever you need help.
