i was in holidays in Miammi and they charge me 10.5 dolares for roaming 581 580-4001 ?
i was Miammi and chargd 10.5 dolares for roaming to this number 581 580-4001 which i never called , how do i get my money back?
Did you check your voicemails?
i dont remember ...maybe?
is this 10.5 for the voicemail? how can i disable this feature? because i travel a lot and i do not want to be charged again..
Carla Francisco wrote:
is this 10.5 for the voicemail? how can i disable this feature? because i travel a lot and i do n...
Don't call, don't pick up the phone, and don't check your voicemail while in the US. Safest way is to set your phone to airplane mode and just enable WiFi.
ok, thank you!
Thank you very much for you advise!!
Happy travels, Carla 🙂
Chad told me it was not possible to disable my voicemail is that right Sophia?
Yes, he is correct 🙂 However, if somebody leaves a message and you don't check it, you will not be charged. We weren't contradicting each other haha.
How do i remove the voicemail?
You cannot...but you're only charged if you retrieve the messages with your phone.
ok i understand, Thank you!
