I Phone info
Hi, can we use a I phone 4 locked with Telus, and use prepaid sim card with Koodo?
Yes, that should work without any problems, Jenny. I don't even think you will need to unlock your iPhone!
Sophia wrote:
Yes, that should work without any problems, Jenny. I don't even think you will need to unlock you...
Thank you!
This will give you the steps to activate your iphone 4 if it does not work when you insert the sim card http://help.koodomobile.com/plans-add-ons-data-and-other-services/iphone/how-do-i-activate-my-iphone
Dennis wrote:
This will give you the steps to activate your iphone 4 if it does not work when you insert the si...
Thank you!
