I need help getting by a iphone 4 passcode
  • 6 August 2015
  • 13 views
I need help getting by a iphone 4 passcode. I have tried both dsfu mode and the mode in which you hold down the home button than turn it on. Both work, however they only get half way through in than which the phone turns on, and itunes pops up saying it wants me to allow access through the iphone for itunes to do this. Any idea how to do it?
If you are trying to get past the passcode, you Can't !!!   That's why the password is there.
It should work Are you able to plug in another phone with iTunes to test it? .
I think you will need to restore the phone from the latest backup, no?
I think you will need to restore the phone from the latest backup, no?couldnt your do a fresh restore via dfu. iTunes should ask you once your are in DFU Or recovery mode
Userlevel 3
I think you will need to restore the phone from the latest backup, no?Connect the phone to iTunes via a computer and follow the instructions to update and restore the phone to factory condition. WARNING! All your data will be lost and the phone will have to be setup from scratch.
