I'm not able to send international texts or make calls from Spain. I can receive texts and data works.
I'm not able to send international texts or make calls from Spain. I can receive texts and data works. I have both voice and data roaming monthly add-ons activated. I have also tried removing the SIM card and toggling the airplane mode to reset the connection. I am using an iPhone 5s. Any ideas?
Give a different texting app a shot. Are you doing +[country code] when you text or call?
Yes, I am using the +[country code]. I tried entering the numbers manually instead of using contacts to be sure.
Kurtis Schram wrote:
Yes, I am using the +[country code]. I tried entering the numbers manually instead of using conta...
Hey Kurtis, let's give this another shot to refresh settings: set your phone in airplane mode for about 15 seconds.  Please get back to us and let us know if it works
Thanks Josie, it is working now. Did you change something on your end?
Great stuff!!  Thought it'd be worth a try to refresh on our end but think it was another attempt to reset that kicked it in so to speak.  Enjoy Spain!
Can you see which network you're connected to for roaming? And if you have the network selection to connect to any type of network?
