I have and iphone 4 that's fully paid I was wondering how much it would be to upgrade and what phones I could upgrade too?
Hi Kathleyn, you can upgrade to any phone you want. Since your iphone 4 is fully paid off, you can pick a tab and use that on any phone you want. Tab S - 150 off Tab M- 300 off but requires at least a $30 plan and it has a $5 monthly tab charge. Would you like to stick with iOS or do you want to try out android? If you're a loyal iphone user, the 5s is $275 right now on tab M. Otherwise there are many other options.
Daniel Kim wrote:
Hi Kathleyn, you can upgrade to any phone you want. Since your iphone 4 is fully paid off, you ca...
How much would it cost to upgrade to the 5c?
Userlevel 2
The Iphone 5C is $75 on tab medium. Hope that helps. 🙂
