I HAVE AN IPHONE FOR FROM ROGERS
WOULD IT WORK WIITH KOODO
ONLY IF YOU GET IT UNLOCKED FIRST
Luckily for you the Rogers version of the iPhone is unlockable, so once you do that your good to go! 🙂
LOUD NOISES! Anyway, unless you're currently a Rogers customer I wouldn't recommend that you unlock your iPhone. Rogers will unlock your phone for $50 if you meet certain conditions. If you're not a customer, it'll cost you over $100 to have your iPhone unlocked. In that case, it'll be better for you to trade your phone on Kijiji.
Userlevel 4
LOUD NOISES! Anyway, unless you're currently a Rogers customer I wouldn't recommend that you u...I DON'T KNOW WHAT WE'RE YELLING ABOUT!
LOUD NOISES! Anyway, unless you're currently a Rogers customer I wouldn't recommend that you u...AHHHHHH..... THIS IS SO MUCH FUUUUUNNNNN
LOUD NOISES! Anyway, unless you're currently a Rogers customer I wouldn't recommend that you u...IS IT PHONE? OR MY EARS ARE RINGING??
LOUD NOISES! Anyway, unless you're currently a Rogers customer I wouldn't recommend that you u...I'm a Koodo customer ,so it should work shaweet
LOUD NOISES! Anyway, unless you're currently a Rogers customer I wouldn't recommend that you u...It should work only if you unlock it from Rogers first. Any unlocked iPhone will work Koodo
LOUD NOISES! Anyway, unless you're currently a Rogers customer I wouldn't recommend that you u...Any unlocked iPhone 3G and later that is.
