I am going to the Uk and need a phone plan. Can I order more than one phone plan to get more texts?
I am going to the UK and need a phone plan, but I will be sending more than 75 texts. Is there any way I can order a plan more than once to get more texts?
You are only allowed the same add-on once per billing cycle so no you can't stack the text plan. I would suggest unlocking your phone and getting a prepaid sim once you arrive in the UK if you plan on doing a lot of texting.
If you will have wifi frequently where you are going you can use that along with a texting app instead of getting a prepaid sim.
Once your phone is uncooked, you can go to that site (http://prepaid-data-sim-card.wikia.com/wiki/Prepaid_SIM_with_data) and you'll find all the relevant information about différents carrier available in UK and their prepaid cards
