how to talk to a real rep??
  • 28 June 2019
  • 3 replies
  • 241 views
I want to switch to Rogers because they have better deals and services 🙂
Hi,
What Rogers deal was it?
Did you want to see if Koodo will match?
If you just intend to port over you don't need to speak to a rep at all. You just start up with Rogers by requesting to port your number over and you will get a final bill from Koodo and you pay it and that's it.
I wouldnt be loyal to Koodo.
If Rogers has a better plan or deal that fits your life situation, i recommend you switch right away before the deal ends.
