how to check international long distance minute usage on self serve
Unfourtunatley you can't you just have to keep track of it on your own on your phone through the call log.
Actually, Click "Airtime" under the Usage then you will see all the numbers you made/received as well as  duration.
You can choose "Long distance" with drop dow menu with "Show" tab.
Mayumi wrote:
Actually, Click "Airtime" under the Usage then you will see all the numbers you made/re...
Oh really I had no idea they added that ability that's awesome, thanks for the tidbit of knowledge Mayumi ☺️
Yes, there are not too many great things with the new self serve site but this is a great feature to have  ;)
Thanks for the info Mayumi! Really helps.. :-)Not surprisingly the Koodo rep said that you couldnt do it and that I needed a pen and paper to keep track!! LOL!!
Next time teach him how to do it! 😛
Oh how I have longed to be able to view my long distance usage, but I can't find what you're suggesting.
When I use the prepaidselfserve.koodomobile.com site, and the Base Plans & BOosters tab, and the Usage History, there is no airtime word listed. The table only lists: Call Type ,   Originating #,   Destination #   , Originating Location ,  Destination Location,   Duration,  Data Usage,  Usage Type ,  Charge
